Old 10-16-2010, 09:56 PM   #11
adam1981
Drives: 2008 Yaris S
OK. I just noticed you have an 08 sedan. On that 4A-5 is yellow instead of green.
I have an 08 Sedan fuse box on my test bench, and I also see the missing wire in 4A-20 (which the EWD for an 08 sedan says should be there). Those two wires are actually tied together as a single input into the ECM, so you probably only need the yellow and that is probably the reason for the lacking blue.
Identified all of the wires and confirmed they are the right ones! Thanks for your continued help! However, they have proven difficult to tap because of the little slack in the harness.
So...I am going to have to connect all the door and truck triggers together. Got to thinking though, when I do this - the Driver Info Center is going to show all doors opened when only one actually is...
Do you know if I could place a diode in line with each of the taps before I tie them together to prevent the problem caused by just tying them all together - to maintain the integrity of each circuit? Will a diode pass the negative/ground provided by the switching?
adam1981 is offline   Reply With Quote
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
