Old 10-16-2010, 10:01 PM   #11
Originally Posted by adam1981 View Post
Identified all of the wires and confirmed they are the right ones! Thanks for your continued help! However, they have proven difficult to tap because of the little slack in the harness.
So...I am going to have to connect all the door and truck triggers together. Got to thinking though, when I do this - the Driver Info Center is going to show all doors opened when only one actually is...
Do you know if I could place a diode in line with each of the taps before I tie them together to prevent the problem caused by just tying them all together - to maintain the integrity of each circuit? Will a diode pass the negative/ground provided by the switching?
Yes, you can diode isolate them to keep them separate. You would tap each door wire and insert a diode between each and the door open input on the alarm. The line on the diode needs to be towards the alarm side.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
