Originally Posted by dean_park
CTScott, are these kits only from the ECU to the switches? Or do they include wiring from the clutch switch too?
I have momentary switches, resistors and a Toyota clutch switch so far, just looking to see what I need for wiring to complete an 07 manual CC install.
The Cruise Control Clutch Switch has its own connector. I have some of the pins (part number 82998-24380), but not the connector housing (part number 90980-10906). The connector housings are semi-custom ones made for Toyota by a couple of connector manufacturers, so they are quite difficult to obtain, other than directly from Toyota. I can provide you with the two pins and you can either order the connector from Toyota, or insert the pins into the switch's connector and pot them with silicone or epoxy.
