Old 12-15-2010, 05:11 PM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by cdydjded View Post
1. Can you explain to me what is your logic on using a manifold from an engine that is 1.8 liters & revs 8000rpm on a 1.5 liter that revs 6300rpm?
2. Are you aware that intake manifolds are designed to work within a specific RPM range?
3. I dont get why you would think that the factory manifold from the 2ZZ would be a better manifold than a custom one engineered to work for a specific engine combination.
1. I am no expert in intake manifolds but I am sure this manifold will definetly show more gains than the stock one. Since it was used on a 1.8L engine which revs 8000rpm it will surely be a plus with a 1.5L turbo engine.
2. I am sure it is the case, but who cares now that I am turbocharged. The stock intake wasn't designed to be used with forced induction.
3. The only answer for this is the price. The 2ZZ manifold + 2ZZ TB cost me half or lower than a quoted custom intake manifold only!
Parmas is offline   Reply With Quote
Old 12-15-2010, 07:12 PM   #2
cdydjded
Drives: Yaris LB Turbo
1)Again you yourself admit no expertise on intake manifolds. So your logic makes no sense. You are going to waste your time & money.
2)You are correct about the stock manifold, but no one has reached the max limits of it. And the 2zz was also never designed for boost.
3)You will never get anywhere by cutting corners, especially price. Cheaper is never better. There are many reasons custom intake manifold are expensive.
Old 12-15-2010, 07:51 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Well, the way you're giving advice you seem to be an expert on intakes manifolds. So how would you go about improving forced airflow without spending 5 grand on design and testing until you have the best possible flow you can have?
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
