Old 12-15-2010, 07:12 PM   #11
cdydjded
Drives: Yaris LB Turbo
Originally Posted by Parmas View Post
1. I am no expert in intake manifolds but I am sure this manifold will definetly show more gains than the stock one. Since it was used on a 1.8L engine which revs 8000rpm it will surely be a plus with a 1.5L turbo engine.
2. I am sure it is the case, but who cares now that I am turbocharged. The stock intake wasn't designed to be used with forced induction.
3. The only answer for this is the price. The 2ZZ manifold + 2ZZ TB cost me half or lower than a quoted custom intake manifold only!
1)Again you yourself admit no expertise on intake manifolds. So your logic makes no sense. You are going to waste your time & money.
2)You are correct about the stock manifold, but no one has reached the max limits of it. And the 2zz was also never designed for boost.
3)You will never get anywhere by cutting corners, especially price. Cheaper is never better. There are many reasons custom intake manifold are expensive.
cdydjded is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
