Old 12-12-2010, 08:26 PM   #11
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
Originally Posted by Parmas View Post
The problem is about sure that is a software issue but we need Haltech support to solve it before we continue.... sooo the car goes back again into my fu..ing garage.
If haltech will not solve it within the next month I have no choice but to make custom triggering wheels for the crank and the cam using Haltech Hall Effect sensors.
I hope this would be the last issue as I am really pissed of about this engine and it is making me sick.
they (haltec), may have told u this already, the crank trigger settings are the same as the scion tc (they flew to our shop to create basemap on our dyno). are you using the sport 1000 or sprint 500? if you ever run into the issue of accelerating hard thru the gears and then the car hits a "cut", pm me and ill tell u the fix, has to do with the crank trigger voltage and filter settings.
cool build!
Ptuning.com
Blown_xa is offline   Reply With Quote
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
