Old 12-13-2010, 08:19 AM   #11
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by Blown_xa View Post
they (haltec), may have told u this already, the crank trigger settings are the same as the scion tc (they flew to our shop to create basemap on our dyno). are you using the sport 1000 or sprint 500? if you ever run into the issue of accelerating hard thru the gears and then the car hits a "cut", pm me and ill tell u the fix, has to do with the crank trigger voltage and filter settings.
cool build!
Hi man, the issue wasn't the triggering but the ignition modules. Haltech replaced them with built in ignitor coils and worked like a charm.
Now I am tuning the engine myself and till now I done mapping of the engine with 9psi boost and 5000rpm [with AFR LOW 14 / HI 10.5 (boost) ]. This week I am preparing the car for the final tune which is the 2ZZ intake. If all goes fine, I have to retune the engine for the larger o/d of the 2ZZ intake Throttle Body (70mm) and runners
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
