Old 12-15-2010, 05:11 PM   #11
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Originally Posted by cdydjded View Post
1. Can you explain to me what is your logic on using a manifold from an engine that is 1.8 liters & revs 8000rpm on a 1.5 liter that revs 6300rpm?
2. Are you aware that intake manifolds are designed to work within a specific RPM range?
3. I dont get why you would think that the factory manifold from the 2ZZ would be a better manifold than a custom one engineered to work for a specific engine combination.
1. I am no expert in intake manifolds but I am sure this manifold will definetly show more gains than the stock one. Since it was used on a 1.8L engine which revs 8000rpm it will surely be a plus with a 1.5L turbo engine.
2. I am sure it is the case, but who cares now that I am turbocharged. The stock intake wasn't designed to be used with forced induction.
3. The only answer for this is the price. The 2ZZ manifold + 2ZZ TB cost me half or lower than a quoted custom intake manifold only!
Motor Longevity Pavel Olavich DIY / Maintenance / Service 10 03-17-2012 11:43 AM
cali yaris built motor cali yaris Performance Modifications 83 09-03-2009 11:08 PM
Fan motor noise... 500snakz General Yaris / Vitz Discussion 10 12-01-2008 02:43 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
Exchanging Motor on a Liftback 1.3 Lt weckjuan Performance Modifications 8 11-12-2006 10:58 AM
