Old 10-25-2012, 03:09 PM   #1
Herder
Greenie
Drives: 2010 Yaris Liftback 3dr
CTScott, you still have any stalks? I have a 10' LB Auto no power package
Herder is offline   Reply With Quote
Old 10-25-2012, 03:17 PM   #2
I do indeed. I replied to your PM.
Old 10-25-2012, 10:20 PM   #3
alpha1
Drives: 2011 yaris 1.5 Auto-sedan
I just installed the cruise control ordered from CTScott for $40.00 stalk & shipping and it was simple, relatively quick (about 1 hour total), and works great.
Installed on car listed 2011 yaris auto sedan with power windows/doors/ & blinking light on dash for immobilizer etc.
After disconnecting the battery, I only had to 1. remove the two Torx screws with a T-30 2. lift the air bag to expose the area to put the new stalk in and push it through the 3. new hole I drilled with a 1 inch drill (did not have 1& 1/8). 4. I then screwed in the 2 new phillip screws supplied by CTScott. 5. I then disconnected the white plug from the stearing column and Connected the new white plug on the stalk. 6. I then disconnected the other end of the original wire that had the white plug and the other end was a clip on wire to the air bag area; and connected the new slip on wire here and I am done except for reconnecting the air bag with the torx screws. (I never had to nor did I disconnect the air bag & other yellow wires) (Both yellow wires stayed intact from the air bag to the stearing column the entire time). (only 1 wire was removed to install this)
To save someone else time..........A regular T-30 usually comes in a box with a simple straight screw driver type handle to turn the T-30. I was unable to turn this with my hand strength. I quickly picked up my 1/4 inch rachet set and a small extension and added a 6.5mm socket and slipped the T-30 into the 6.5mm socket. It now became simple to turn the T-30 screws on both sides of the column (Leverage is great). Also squeeze the top center of the white plug and center of the clip to remove that one wire that you are replacing.
It is really simple, there was just a lot of previous older models and many pages of diagrams listed that no longer were needed for new models etc. that did not have all the wires etc. coming to the stearing column that made it a little confusing. The newer cars will all probably be simple with the power windows etc. using the oem stalk from CTScott.
Thanks Again.....Works great.... Great buy for oem cruise control....dash board icon shows it's working....tap for increase speed works...etc. etc.
I just read the Birthday listing, so ......... Happy Birthday CTScott
alpha1 is offline   Reply With Quote
Old 11-18-2012, 09:57 PM   #4
Machinist
Drives: Blue 2dr. LB
CTScott, you still have any stalks? I have a 2011 3dr. power doors, locks, etc. Manual trans.
Machinist is offline   Reply With Quote
Old 11-18-2012, 10:20 PM   #5
Yes. I will PM you.
Old 11-23-2012, 10:33 AM   #6
rtom
Drives: 2010 Yaris 3-door liftback MT
One more for me?
Hi CTScott,
I finally have time for this mod -- so I would be interested in buying what I need for my '09 LB, with manual transmission but no power package.
Please PM me & I'll paypal you the funds. If I need more than just the stalk, please let me know. I recall for MT there is a clutch switch to install?
And yes, I'll re-read your "DIY Cruise Control FAQ (2006-2010 Yaris)" thread -- it has been a few years.
Thanks!
rtom is offline   Reply With Quote
Old 11-23-2012, 11:02 AM   #7
rtom
2010 not 2009 LB
Too much turkey -- mine's a 2010, not a 2009!
Old 11-23-2012, 05:15 PM   #8
No problem - PM sent.
Old 04-25-2013, 12:37 PM   #9
n01tk
Drives: 2008 yaris
CTScott, just bought 2008 Yaris sedan ( no power option). My wife wants cruise. Do you have the stalk, jumper cable and connectors. Nova Scotia, Canada
n01tk is offline   Reply With Quote
Old 04-25-2013, 02:06 PM   #10
PM sent.
Old 01-18-2013, 01:16 PM   #11
SirSchwank
Drives: 07 Yaris LB
I'm finally looking to add this as well. Do you still have kit for an '07 LB MT?
SirSchwank is offline   Reply With Quote
Old 01-18-2013, 01:22 PM   #12
Yes. I will PM you the info.
Old 01-30-2013, 09:30 PM   #13
jecurtin3
Drives: 09 yaris rs
CTScott,
I'll take a kit if you still have one. I have a '09 3dr. Do you take CC's?
jecurtin3 is offline   Reply With Quote
Old 02-01-2013, 12:50 AM   #14
UberSilver
UberSilver's Avatar
Drives: 08Yaris2D, 88LandCruiser.
Originally Posted by jecurtin3 View Post
CTScott,
Me2
UberSilver is offline   Reply With Quote
Old 02-01-2013, 06:26 AM   #15
Pm's sent.
Old 02-01-2013, 08:07 AM   #16
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
Pm sent =)
-Derrick-
Old 02-25-2013, 11:47 AM   #17
DirtKurt
Drives: 2010 Yaris
Hey would like to get this for my girlfriends Yaris, 2010 4dr HB. power windows and locks. Let me know, Thanks Kurt.
DirtKurt is offline   Reply With Quote
Old 02-25-2013, 12:49 PM   #18
PM sent. By the way, you are about two weeks late. Cruise control would have been the ultimate Valentine's day gift for her.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
