Old 12-22-2010, 11:18 PM   #1
YAR1S
YAR1S's Avatar
Is this DIY fairly easy or difficult?
-Jen <3
Old 12-23-2010, 07:12 AM   #2
It's fairly easy. On your 08 it would require adding the pin to the ECM connector, running the wire through the passenger side firewall grommet and under the dash, across to the steering column, adding the two pins to the connector on the column, removing the airbag, drilling the 1" hole for the stalk in the lower steering wheel cover, mounting the stalk, and moving the horn wire from the existing connector to the stalk's connector.
No one has written up a soup to nuts DIY on doing an OEM stalk on an 07 or older, but all of the pieces mentioned above are detailed in the DIYs linked to in this thread:
http://www.yarisworld.com/forums/showthread.php?t=25515
Old 01-03-2011, 01:17 PM   #3
timmay
Drives: stripped sedan
With all of Scott's posts and fast shipping, I will have CC before my payment books arrive. He is a real stand-up guy, thanks.
timmay is offline   Reply With Quote
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
