Old 12-23-2010, 06:58 AM   #1
Hella's website shows them as drawing 12A (which seems to be typical for most of Hella's horns), so you would need the relay, as the stock horn driving circuit is only rated for 10A.
Old 12-23-2010, 04:03 PM   #2
severous01
you answered your own questions...
the hella is higher rated and will blow the fuse if it draws full current. and if the fuse is there to protect the circuit from more than 10 amps...then the wires are rated at 10 amps as well...and so on. so, if you put a 15a fuse in there you'll likely cause problems.
Old 12-23-2010, 04:07 PM   #3
That was my answer to his question...
Hella taillights installed Brian Cosmetic Modifications (Exterior/Interior) 20 09-18-2011 11:41 AM
Hella Twin Supertones lilredrocket Cosmetic Modifications (Exterior/Interior) 40 03-06-2011 05:44 AM
MI Hella taillights for the sedan big lo General Yaris / Vitz Discussion 2 06-16-2010 11:09 PM
HELLA HORN INSTALLATION jaimico In Car Entertainment + Electronics (audio / video / alarm) 3 02-08-2009 05:09 PM
Hella 118db horns Galavoxx Cosmetic Modifications (Exterior/Interior) 31 03-27-2007 11:36 AM
