Old 01-14-2011, 05:21 PM   #1
matthewai
matthewai's Avatar
Drives: it is kinda stock
rear blinkers
hey guys i know on my car 010 sedan the rear blinkers are yellow or amber is it possible to get red bulbs to put in there ? what type of bulbs are the stock yellow ones is what im asking and can you get that size in red thankss
Old 01-14-2011, 07:10 PM   #2
http://www.yarisworld.com/forums/showthread.php?t=1367
red turn signals would be illegal in California, FYI
Old 01-14-2011, 07:30 PM   #3
matthewai
matthewai's Avatar
oh really i thought just the front turn siggs had to be yellow and the back could be red or yellow but im in ny so im sure its different thanks though
but you know whats not illegal, marijuana i would move there just for that reason alone haha hopefully other states follow suit
Old 01-14-2011, 07:37 PM   #4
matthewai
matthewai's Avatar
so i looked at that tread are the bulbs different on the sedan cuz it says hb rear turn signal 7507a and i found on another site that for the sedan it says 992/7440al rear turn sigg
Old 01-14-2011, 10:17 PM   #5
oh you're right I was hallucinating, it's the front that can't show red or blue lights.
Old 01-14-2011, 10:51 PM   #6
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Hallucinating probably from said cannabis.
Old 01-15-2011, 02:06 AM   #7
matthewai
matthewai's Avatar
bahah this could be the start of a funny thread...
Old 01-15-2011, 12:49 PM   #8
zuberio
Joined 3/08 ... really
zuberio's Avatar
Drives: '07 Sedan
Anyone else suddenly get the munchies?
zuberio is offline   Reply With Quote
Old 01-15-2011, 12:51 PM   #9
matthewai
matthewai's Avatar
im about to in about 10 mins
Old 01-15-2011, 01:18 PM   #10
matthewai
matthewai's Avatar
okay now i do ...hhah.. but back to these blinkers im going out to try to get some red 992/7440 if i find the right ones maybe ill do the swap today
Old 01-15-2011, 04:23 PM   #11
matthewai
matthewai's Avatar
these would prob be fine right 7440 red ?
http://www.superbrightleds.com/cgi-b...ecs%2F7443.htm
Old 01-15-2011, 07:28 PM   #12
matthewai
matthewai's Avatar
bout to order them
Old 01-17-2011, 05:31 PM   #13
matthewai
matthewai's Avatar
just did from superbrightleds hope they work
Old 01-18-2011, 09:16 PM   #14
matthewai
matthewai's Avatar
also does the whole rear light need to come out to change the bulb or just the inside trunk lining?
Old 01-20-2011, 11:31 PM   #15
matthewai
matthewai's Avatar
just put them in they look great easy swap although it took me a bit to get them all the way in and i had to bend the terminals just a tiny bit so they made contact with the housing. hope they dont jar loose after hitting bumps i think theyll be fine...right guys?
Old 01-21-2011, 12:30 AM   #16
matthewai
matthewai's Avatar
wellp for some reason they do the "fast" flash now when used individually but all lights work any one know bout this? (wrong bulb its a 7440) (bad connections) when using hazards they all flash at the same slow pace
Old 01-21-2011, 12:39 AM   #17
SAV912
Pirate Yaaaaris
SAV912's Avatar
Are they LED bulbs or standard incandescents? If they're LEDs, they don't draw enough power and the 'fast flash' is caused because the car thinks the bulb is blown out altogether. I can't remember the correct term for it, but a relay or resistor or something needs to be installed. If they are just normal bulbs, then you may have a problem with the fuses.
Seeing that you ordered from SBLEDs like I have before, I'd wager your problem is the former. There are easy fixes for it, but just bulbs alone will lead to fast flashes.
-SAV
Georgia Bulldogs!
'09 Yaris LB 5MT Sold.
Old 01-21-2011, 01:34 AM   #18
matthewai
matthewai's Avatar
well they are all leds i think 15 led 7440 12v wedge base there actually is a resistor inside the light under the leds and tiny circuit board did i get the wrong one was i suppose to get 7443? i have 2010 sedan
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
