Old 01-31-2011, 02:14 PM   #1
Soner
Send a message via Yahoo to Soner
I wish you were near me. That would have been perfect.
I don't know if I can do it otherwise I would have no problems at all buying your custom made pins. If you can show me step by step with pictures what I should do, I may try it I don't know. I am worried I will plug it in somewhere and mess up the electrical system.
Soner is offline   Reply With Quote
Old 01-31-2011, 03:06 PM   #2
It's really not that bad, especially since the airbag removal part is already complete. Link #6 in my FAQ below shows the details of adding the pin at the ECM. The other two pins go into connector D3 on the steering column, which currently only has the one wire for the horn on your car. One of those pins connects to the wire to the ECM pin, and the other gets connected to a ground point.
http://www.yarisworld.com/forums/showthread.php?t=25515
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Cruise Control on 2010 Canadian Manual Kaya B. DIY / Maintenance / Service 25 10-01-2010 03:31 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
