Old 01-31-2011, 03:47 PM   #1
Soner
Send a message via Yahoo to Soner
So, don't I have to remove airbags etc again to connect one part of your pins to the Cruise Control? Also, how do I run the other end of your cable to the engine bay?
Soner is offline   Reply With Quote
Old 01-31-2011, 04:29 PM   #2
If your mechanic connected the wire from the cruise control stalk to the spiral cable (AKA clockspring) then the airbag doesn't have to come back off, since you just have to make the connections at the other end of the spiral cable.
The wire to the ECM pin can be run through the firewall in a few different places, but most people bring it through the grommet for the AC drain hose, which is about a foot below the ECM.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control on 2010 Canadian Manual Kaya B. DIY / Maintenance / Service 25 10-01-2010 03:31 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
