The DIY for the MicroImage Fog Light kit shows the wiring between the fogs and the connector in the under hood fuse panel. Do that under the hood, and then on the inside, add the fog light relay (also shown in the DIY). Install the replacement stalk, and you would then be done for normal operation. To allow the fogs to run with the parking, lows and highs, Snip the wire in pin 4 (on your 2010 I believe that wire will be white instead of orange), cap off the harness side, and connect the connector side to the white wire in pin 13.
![]() For the lighter one, look at my remote start DIY and connect the gray wire from the outlet to the constant power. Add a 15A in-line fuse between the tap point and the outlet.
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Remote Start DIY Wiring Guide 2006-2010 Yaris | CTScott | DIY / Maintenance / Service | 272 | 01-22-2022 10:02 PM |
| Relay Wiring for DIY LED Daytime Running Lights (DRL) | zuberio | DIY / Maintenance / Service | 20 | 07-07-2011 08:02 PM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 11:48 AM |
| DIY Requests. | TinyGiant | DIY / Maintenance / Service | 13 | 10-29-2008 10:39 AM |
