Old 03-15-2011, 02:50 PM   #1
Crashingtehwarehouse
Drives: '07 Yaris 3D
If it's not the dimmer rheostat position, check the MET and GAUGE fuses in the under dash fuse panel (literally under the bottom of the dash, by the hood release lever). The prior owner may have had an aftermarket radio installed and popped one of the illumination related fuses when deinstalling it.
You mean popped as in it's not seated properly or popped as it the fuse is blown? And how will I know which fuse is which?
Thanks
Crashingtehwarehouse is offline   Reply With Quote
Old 03-16-2011, 12:07 PM   #2
Thanks
Popped as in blown. The fuse cover has a diagram on it that shows which fuse is which.
2010 Yaris 3DR LB: Backup Lamp Illumination Distance msmitka General Yaris / Vitz Discussion 21 12-27-2011 01:25 PM
Light Bulb Numbers For Interior Illumination privateyeblckbx Cosmetic Modifications (Exterior/Interior) 0 05-16-2010 04:59 AM
part #'s for interior illumination package bladesmith6 Cosmetic Modifications (Exterior/Interior) 4 05-03-2010 11:33 AM
Tachometer Illumination Thirty-Nine DIY / Maintenance / Service 4 05-29-2009 04:59 PM
Tach Illumination wire Liu997 DIY / Maintenance / Service 6 05-29-2009 11:11 AM
