Old 04-16-2011, 01:04 PM   #1
johnny_vitz
Drives: 2005 Toyota Echo
Originally Posted by Bluevitz-rs View Post
All you'd have to do is take an existing system, like the zage kit sold at Micro Image, modify the spring in the waste-gate and add an electronic boost controller. It doesn't mean you're locked into not using boost.
How do you make more power or torque without any boost though?
To attempt to answer cali's Q - I've never heard or seen any automotive application with this set-up, they all make boost
Although, with that set-up, you could use your controller to only run say 3 pounds and be safe for your engine
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 04-16-2011, 02:19 PM   #2
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
Your car is still in vacuum @wot so 0 psi is more than what the engine would under normal conditions. Only way to bring you n/a car close to it is to free up all the restrictions in the intake system.
Yoda is offline   Reply With Quote
Old 04-16-2011, 06:46 PM   #3
johnny_vitz
Ok, i've never measured myself, but isn't it supposed to be only 1 or 2 in. vac (very close to 0) @WOT? I could see picking up a tiny bit, but nothing worth the money you would pay for a turbo kit.
We need a guinea pig...
Old 04-16-2011, 08:56 PM   #4
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
You can disconnect your wastegate acuator rod... Result is 0psi...
cdydjded, you answered it yourself... This method would work perfectly if there is enough flow.
It's a cool idea but definitely not worth the hassle or cost.
Focus_Sh1ft is offline   Reply With Quote
Old 04-16-2011, 09:28 PM   #5
turboecho2005
turboecho2005's Avatar
If your wastegate is accessible it shouldnt take more then 5 minutes to pull the pin holding the arm.
Project Slowtop - Twin Engine 4AGE Blacktop Vitz - Twin Turbo - 503hp
1987 Nissan Maxima - 40,000 original miles - Slammed
1991 Isuzu Impulse RS AWD Turbo - approx 250hp - Winter Beater
1989 Isuzu Imark RS - Mint Condition - 0 rust - 100% factory :) - Summer Cruiser - 100% restored
1986 VW Jetta Wolfsburg - 120,000km - Mint condition. TDI swap in progress
turboecho2005 is offline   Reply With Quote
Old 05-23-2011, 10:57 PM   #6
Viperoni
ding ding ding
I like the idea Blue, but there's no way I, personally, could keep a car at 0 psi boost when it could do more :D
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
HKS turbo for mk1 yaris 1 litre 1SZ-FE nuttallacpw Items for Sale by private party 10 01-26-2011 05:03 PM
Oil Pressure problem... Suspecting Turbo issue Parmas DIY / Maintenance / Service 16 12-13-2010 04:23 AM
Turbo Project Yaris TS 1.8L CASTREX Yaris TS Talk 40 08-21-2009 10:24 AM
HKS turbo timer type 1 Tamago Performance Modifications 3 07-21-2009 11:59 AM
