![]() ![]() Drives: Toyota Belta Join Date: Feb 2010
Vibration on idle & rough start
Hi, guys. I wanted to ask on how to fix the vibration on idle and rough start problem in my '06 Belta (1KR-FE, 1.0L I3).
The thing is that, since a few months I've been facing vibration on idle on D/N/R while the car is stationary. Their isn't any vibration while driving the car. Sometimes the vibration completely vanishes and sometimes it vibrates hardly. The second thing is that I've been facing rough start problems since about two weeks, whenever I start the in the morning it would stall on the first start. Then when I start it on the second try it would start normally and perfectly. I am having doubts on the fuel filter, and I am planning on getting it replaced pretty soon I just wanted to see what the experts here would recommend before I do something. Note: I've recently changed the spark plugs, added a bottle of STP super concentrated Fuel Injector cleaner on the last tank top-up. The car is 31,000Kms driven haven't faced any problems other than these since I've imported it back in 2007 when the reading on the odometer was 18,000Kms. Thanks to everyone in advance, happy motoring!
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Clean the MAF sensor with rapidly evaporating cleaner. There's a DIY somewhere. It improved idle for me.
Was going to say spark plugs - it improved the starting and idle for me. Could be battery - replacing it also improved starting for me. I've come to regard some vibrations at idle when stopped as normal. There's a certain harmonic that just resonates sometimes. |
#3 | |
maybe you need new plugs. If they're only standard plugs their time is due.
#6 | |
So quite obviously you don't need to change the plugs if there's only 500 km on them.
#7 | |
Are they the correct type of plug?
OEM Denso SK20HR11 Iridium, they are the OEM ones that come with the 1KR-FE engine.
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
I'm having the same issue, changed the plugs/coils/MAF/air filter in the last three weeks, the problem is 95% gone with only a rough idle when a fan or something kicks on. I'm going to DIY a ground kit for it this afternoon and see ifthat helps.
Of course my car has about 450,000 miles on it so.... |
#11 | ||
![]() ![]() ![]() ![]() ![]() Drives: 2013 Chevy Spark 1LT 5-speed Join Date: Oct 2008
#12 | |
#13 | |
advocatus diaboli
Quoting myself here(hoping the universe doesn't implode because I did) that ground kit did the job. I was skeptical it would have that dramatic of an effect, I just figured my stereo would be cleaner(which it is!). I made my own for about 15 bucks, I'm going to make one for all of my cars now. |
#14 |
where did you mount all the ground points?
#15 |
advocatus diaboli
I pretty much used the same locations this guy did, except I added a couple more to the body.
http://www.yarisworld.com/forums/showthread.php?t=2313 |
#16 |
Why would I need a ground kit?
#17 |
advocatus diaboli
Basically it helps clear electric noise that may interfere with some of the electronic equipment on the car, that's about the best I can do...I'm not an electrical engineer. It did make a difference though, a noticeable one. Mainly I don't get the shakes now when the AC and cooling fan kick on @ idle, which is exactly what I was hoping for.There's a lot more info at that link I posted above. |
#18 |
What if I get the fuel filter and the battery replaced? Would that help in anyway? @CTScott, I really need your input here.
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Car wont start - help! | tamo300 | General Yaris / Vitz Discussion | 14 | 03-23-2010 10:44 PM |
| Rough engine start w/76? | guyver408 | DIY / Maintenance / Service | 12 | 06-26-2009 12:18 AM |
| Rough Idle in drive | toyoman | NY / NJ/ CT / PA | 8 | 04-22-2007 03:40 AM |
