Old 04-17-2011, 07:27 AM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
maybe you need new plugs. If they're only standard plugs their time is due.
Old 04-17-2011, 07:50 AM   #2
Murtaza_murti
Drives: Toyota Belta
Got new plugs 500Kms ago, why would they need replacement?
Murtaza_murti is offline   Reply With Quote
Old 04-17-2011, 08:33 AM   #3
Bluevitz-rs
Because you said you have 31000km on your car and standard plugs only last about 35000km. You did not mention you changed you plugs.
So quite obviously you don't need to change the plugs if there's only 500 km on them.
Old 04-17-2011, 08:34 AM   #4
Bluevitz-rs
Because you said you have 31000km on your car and standard plugs only last about 35000km. You did not mention you changed your plugs.
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 01:39 AM
DIY Cruise Control on 07-08 Yaris (step by step) Vince87 DIY / Maintenance / Service 431 12-28-2020 01:37 AM
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
Rough engine start w/76? guyver408 DIY / Maintenance / Service 12 06-26-2009 12:18 AM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 03:40 AM
