Old 05-14-2011, 06:40 PM   #1
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Check the OCV(oil control valve).
-Type 07 FFL-
My odometer 03/11
Old 05-14-2011, 07:12 PM   #2
special_k_828
Drives: 2006 Yaris CE 2-Door Hatchback
Thanks. Saw your other post in another thread about how to install this part too. Since it's a valve, is there a way to clean it if it's gunked up instead of buying a new one? Some dealers charge $150-$320 for this sucker.
special_k_828 is offline   Reply With Quote
Old 05-14-2011, 11:19 PM   #3
mazilla
advocatus diaboli
mazilla's Avatar
I cleaned mine first too, but It must have been a connection problem within the switch or worn parts because it didn't help. Disconnect your battery and pull the OCV then give it a good hose down with some throttle body cleaner, move the internals back and forth(you can clearly see the moving parts when it's out) to make sure you get all the gunk out.
-Type 07 FFL-
My odometer 03/11
QR Code Window Stickers nick.dollimount Cosmetic Modifications (Exterior/Interior) 23 02-25-2011 06:22 PM
2010 RS Model Code?? revolution Cosmetic Modifications (Exterior/Interior) 10 10-14-2010 05:11 AM
Yaris CDX 1999 P0171 error code Davax DIY / Maintenance / Service 2 08-18-2010 07:14 PM
error code P0171 bronsin DIY / Maintenance / Service 17 03-12-2010 06:22 PM
Check engine code 456 on brand new '09 kameele DIY / Maintenance / Service 3 10-14-2009 11:12 PM
