Old 05-16-2011, 07:04 PM   #1
special_k_828
Drives: 2006 Yaris CE 2-Door Hatchback
try switching gears...
Thanks Marcus.. tried that but no luck. I took off the airbox so I could have more leverage but still, can't get it off. It's really seized on there! Has this ever happened to anybody?
special_k_828 is offline   Reply With Quote
Old 05-16-2011, 08:00 PM   #2
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
I ave the same issue. Mine is literally completely seized onto it. I just gave up.
EDIT: the problem with the design of it, is that if the thign in question gets seized, the whole thing can still pivot inside the rubber in which the linkage sits. The more it seizes, the more it tends to turn inside the rubber instead of on the pivot, which in turn allows for the bushing to seize more by placing less force on it. Vicious cycle.
Old 05-16-2011, 09:37 PM   #3
special_k_828
This is exactly what happened. I'm in the process of trying to cut through the bushing. I'll just try to find a junkyard one or something (if it comes off).
FS: Short Shifter and Bushing dwnhillskater Items for Sale by private party 4 04-14-2010 02:26 AM
NST shifter cable bushing users: Lube up! schleppy Performance Modifications 11 07-05-2009 08:47 PM
NST shifter linkage bushings... DerFlosser Performance Modifications 4 05-21-2009 08:33 PM
NST Shifter Bushing Kit ruimond Performance Modifications 5 12-06-2008 12:48 AM
NEW NST SS Shifter Bushing (AE86) NonStopTuning NonStopTuning 3 10-01-2007 03:12 PM
