Old 05-24-2011, 06:30 PM   #1
BLOODY_STONE
Drives: 2009 toyota yaris 1.3 sedan
so , it wont matter if its synthetic or mineral ?
BLOODY_STONE is offline   Reply With Quote
Old 05-24-2011, 06:42 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
no. What does Toyota tell you to use in your car? For the US it is on the oil cap.
Colin Chapman disciple
Old 05-24-2011, 06:49 PM   #3
BLOODY_STONE
nothing written on the oil cap ...
Old 05-24-2011, 06:42 PM   #4
Happy Little Pony
Drives: 2007 Yaris HB
There's not a lot of difference in your scenario. In a warm weather climate with a car that doesn't have a high performance or turbo-charged engine, the benefits of a synthetic are minor. If you want to use a synthetic for a little more peace of mind, go ahead, but it probably won't affect the longevity of your engine to any great degree.
As long as you use a quality oil and change it regularly, I wouldn't worry.
Happy Little Pony is offline   Reply With Quote
Old 05-24-2011, 06:51 PM   #5
BLOODY_STONE
All i need is outstanding protection & long life ... so all i should care about is interval changing not the type of oil ...
Old 05-24-2011, 07:06 PM   #6
Happy Little Pony
Exactly. In an ideal situation, you can run a synthetic oil longer than a conventional because the synthetics tend to have a more robust additive package. But, as you describe, you live in less than ideal circumstances in a very dusty environment. That will be your problem. Keep an eye on your air filter and your air intake, making sure all of the seals are good and that there are no cracks or leaks. That will have more to do with you engine's lifespan than the oil will.
But especially keep watch on your cooling system. Check your coolant level regularly and watch for leaks! More engines end up on the scrap heap from coolant problems than from oil problems.
Old 05-24-2011, 08:19 PM   #7
BLOODY_STONE
big THANX!! considering synthetic oils ... what do you recommend?
Old 05-24-2011, 11:19 PM   #8
Happy Little Pony
It's hard to say, not knowing what's available to you there. Any synthetic oil that's rated "SL," "SM" or "SN" by the API, or "GF4" or "GF5" by ILSAC would be fine.
Engine oil pump? zahirrahman DIY / Maintenance / Service 3 09-30-2010 01:06 PM
Performance engine Oil xbalance Performance Modifications 2 07-14-2009 03:32 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Spilled oil on engine eii DIY / Maintenance / Service 11 01-28-2009 11:30 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
