Old 06-13-2011, 10:40 PM   #1
Originally Posted by hayden View Post
I'm trying to test the wire right at the stalk, but I think I'm maybe having trouble finding a ground for the negative pokey thing. Do you have suggestions of a ground available near the steering wheel?
I removed all my plastic connectors and just wrapped the ends of wires around each other, put a little solder, and duct taped it. I'm thinking maybe it's the D3 connector but wasn't able to remember how to "unclamp" it.
And it turns out, the extra wire I bought is this thick solid type (think barbed wire with rubber coating) rather than the typical frayed stuff you see in electronics - that doesn't matter does it?
Any bare metal under the dash will make a good ground.
The only potential issue with solid instead of stranded wire is flexibility. Solid wire can't be flexed too much or it will break.
Old 06-17-2011, 10:49 PM   #2
hayden
Drives: asd
I think I'm giving up. I guess I'm a god damned retard because apparently I cannot even make the wires connect. I reran ALL of the wire again, and the connection right at the D3 connector will be fine for 5 minutes, then with changing nothing, the connection will break. I'll check it at the ECM, it's fine, and then check it again at D3 and magically it's working again after changing nothing. And now even when there's a connection right before the D3 connector, moving the CC stalk no longer causes any changes in voltages, meaning there's now also a problem with the D3 connector or something between the D3 and the stalk.
Maybe I'll just put up a craigslist ad asking someone who isn't a retard to do it for me for $50 or something. Anyone in DFW want to make some easy money?
hayden is offline   Reply With Quote
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
