Old 07-14-2011, 02:18 AM   #3
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Originally Posted by caineroad View Post
Hmmm, I got my first car Yaris when I was 18 too
Car is noisy on freeway compare to others like a 2.0 or 2.5L cars, is the engine that roars and i guess insulation isnt the best. But you will get used to it so it's not a problem
When you are in the highest gear(AT) at 50mph, rpm is about 2300, at 60mph is about 2900, and 70mph is about 3200, redline 6300
I think MT has different gear ratio so the numbers would be different.
Actually the numbers I think are about the same. Going 110kph which is roughly.. 70mph it's just a hair over 3000
EDIT: oh wait this kid is Canadian.
Okay well going 50-60kph you're looking at 2800+/- rpm. I usually shift into 4th for overdrive at that speed. The highway noie is there, but I hardly ever notice because I play music. There are thigns you can do like spraying sound insulating foam (sometimes referred to as tar foam) in the wheel wells. I've yet to try the foam bit myself but am looking into it.
Turbocharged Dyno Result cdydjded Forced Induction Forum 24 08-23-2010 10:54 PM
Fluctuating RPM DenverDave DIY / Maintenance / Service 10 02-28-2010 02:47 PM
yaris and yaris S Y@R15 General Yaris / Vitz Discussion 54 09-14-2009 12:40 PM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
Optimal RPM for shifting Gears ? JapRulezz Performance Modifications 8 03-07-2009 04:16 AM
