That's exactly correct. The fuel level sender uses the unregulated battery voltage, so the change from 14.x when the alternator is whizzing to 12.x when you're sitting there cranking the tunes with the engine off makes a difference of up to a full bar.
#2 | |
advocatus diaboli
Drives: 07 Yaris hatch Join Date: Mar 2011
Same question, different thread...can we regulate that voltage somehow? I don't like how much it bounces around my gauge.
-Type 07 FFL- ![]() My odometer 03/11 http://i205.photobucket.com/albums/b...a/2843ed85.jpg |
Yes. You would have to add two 12 volt regulators. One for the ECU-B and one for the MET feed to the cluster.
#4 | |
advocatus diaboli
My gauges sometimes show 15.5-16.5 at the battery, I'd like to stabilize it @ 14 if I can. Could you drop an example link on the part I would need? Thank you for all the
You need to stabilize it low, not high. A regulator doesn't bring the voltage up, it will just take a higher voltage and bring it to a lower stable voltage. The part you want is a simple LM7812 voltage regulator (radio shack usually stocks them). It is a 3 pin device with in, ground and out. Normally you would add two capacitors when using one, but in this case, because you are just regulating a supply that really doesn't need to be regulated you can skip the caps.
| Tags |
| gas bar disappearing |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 07:41 PM |
| How to save on $4 a gallon gas this summer | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 1 | 05-26-2011 08:07 PM |
| Natural Gas Transportation - Why Not? | Kal-El | Off-topic / Other Cars / Everything else Discussions | 1 | 03-20-2011 02:12 PM |
| Economics of Price Gouging and Gas shortages | GeneW | General Yaris / Vitz Discussion | 1 | 10-31-2008 05:20 PM |
| Free gas for any vehicle. | ketel0ne | General Yaris / Vitz Discussion | 4 | 09-19-2006 09:07 AM |
