Old 07-21-2011, 11:42 AM   #1
That's exactly correct. The fuel level sender uses the unregulated battery voltage, so the change from 14.x when the alternator is whizzing to 12.x when you're sitting there cranking the tunes with the engine off makes a difference of up to a full bar.
Old 07-22-2011, 12:25 PM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Same question, different thread...can we regulate that voltage somehow? I don't like how much it bounces around my gauge.
-Type 07 FFL-
My odometer 03/11
Old 07-22-2011, 12:47 PM   #3
Yes. You would have to add two 12 volt regulators. One for the ECU-B and one for the MET feed to the cluster.
Old 07-22-2011, 01:37 PM   #4
mazilla
advocatus diaboli
mazilla's Avatar
My gauges sometimes show 15.5-16.5 at the battery, I'd like to stabilize it @ 14 if I can. Could you drop an example link on the part I would need?
Thank you for all the
-Type 07 FFL-
My odometer 03/11
Old 07-22-2011, 01:44 PM   #5
You need to stabilize it low, not high. A regulator doesn't bring the voltage up, it will just take a higher voltage and bring it to a lower stable voltage. The part you want is a simple LM7812 voltage regulator (radio shack usually stocks them). It is a 3 pin device with in, ground and out. Normally you would add two capacitors when using one, but in this case, because you are just regulating a supply that really doesn't need to be regulated you can skip the caps.
gas bar disappearing
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
How to save on $4 a gallon gas this summer fnkngrv Off-topic / Other Cars / Everything else Discussions 1 05-26-2011 08:07 PM
Natural Gas Transportation - Why Not? Kal-El Off-topic / Other Cars / Everything else Discussions 1 03-20-2011 02:12 PM
Economics of Price Gouging and Gas shortages GeneW General Yaris / Vitz Discussion 1 10-31-2008 05:20 PM
Free gas for any vehicle. ketel0ne General Yaris / Vitz Discussion 4 09-19-2006 09:07 AM
