Old 08-18-2011, 12:15 PM   #1
^ NO.
You need to keep in mind that the total diameter of wheel + tire needs to stay within the 23.xx inch mark. Drop wheel diameter by an inch, means tire sidewall needs to increase by an inch.
Old 08-18-2011, 12:56 PM   #2
3cyltrbo
^ NO.
not unless you don't mind having a slightly different outside rolling diameter
usually an outside diameter of +/- 1/2 inch within stock won't have more than a 3% difference in speedo reading.
meaning if factory is 23.62? , a pretty safe region (outside rolling diameter) is 24 on the high end and maybe 23 on the low end (assuming factory is 23.62 ish??)
3cyltrbo is offline   Reply With Quote
Old 08-18-2011, 07:44 PM   #3
Yaristeve
Drives: 3-door hatch
I know you meant sidewall needs to increase by 1/2 an inch, but OP is a wheel/tire newbie so just to be clear...
Old 08-18-2011, 09:34 PM   #4
SeriousBlack
SeriousBlack's Avatar
Drives: 2007 Yaris RS HB
195/50/16 tires with a 16X7 ET40 rim will not rub unless you are REALLY lowered - a DF210 may still rub. This wheel/tire combo is a good compromise for looks, handling and ride comfort.
If you don't want to "compromise" and want extreme lowering/low offset & wide wheels, be prepared to roll your fenders and trim plastic.
SeriousBlack is offline   Reply With Quote
New Yaris + warranty Question hpvampiress New YARIS Purchase Forum 9 06-29-2009 06:39 PM
Final Drive t0m4s Performance Modifications 17 04-11-2009 03:16 PM
Final Drive t0m4s Central and South America 0 04-07-2009 06:06 PM
Amplifier Watt Question....noob question hasher22 In Car Entertainment + Electronics (audio / video / alarm) 4 09-27-2007 03:59 PM
My final Decision. nick1983 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 07-09-2007 03:30 PM
