Old 09-29-2011, 10:45 PM   #1
auxmike
auxmike's Avatar
Wolfy,
I meant to say they fit snug on the hub and don't wobbel around. Some aftermarket rims require centering rings that sit inside the center hole of the rims properly. These are a perfect, secure fit. No rubbing at all to report after a year. I'm running stock sized tires too.The finish looks great still and I only clean them with soap and water, no chemicals.Don't be spooked by the 6 inch width, it's trivial and these are designed by Toyota for a proper, safe fitment to the car.
Old 09-29-2011, 11:34 PM   #2
Viperoni
Drives: 2005 Toyota Echo
Originally Posted by auxmike View Post
Wolfy,
6" pinches a 205/50 or 205/55 tire, it's much happier on a 6.5" rim.
They do look good on the car though... too bad they don't come in a 16x6.5!
2006 Saturn Ion Redline
2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold
2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped
Viperoni is offline   Reply With Quote
Old 09-30-2011, 10:52 AM   #3
kimona
kimona's Avatar
Drives: 2014 White VITZ
205mm tyres can fit quite "happily" on 5.5-7.5" rims.
Old 09-30-2011, 12:11 AM   #4
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Wolfy,
Oh, they are definitely snug. Particularly when they were stuck to the hub...
Not that that's the wheels' fault. Chalk it up to lovely northeastern weather. Some grease will be applied next spring when I put them back on...
But like auxmike said, they're great!
FS: Yaris RS Alloy wheels W/Tires & Lugs mr.white_hb Items for Sale by private party 23 03-30-2009 10:40 PM
2006 Scion Xa steel wheels... Chupacabra Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 12-07-2008 06:52 PM
