#1 | |
![]() Drives: 2010 AT 5dr Liftback Join Date: Jan 2010
![]() thanks for the quick reply. are you still selling the cheap OEM cruise control stalk & connector cable? I have a US based shipping address in Nogales, Arizona |
Yes. I still have the Stalks with CC wire and mounting screws for $40, as well as the pins needed for 06-08. Theoretically your 2010 AT only needs the stalk, since the US and Canadian 09+ Yaris have the wiring in place, but you may want to take a peek at the ECM connector and the spiral cable connector to be sure.
#3 | |
Can't wait to do this, If the wiring is already in place a friend of mine with a 08' sedan can use the extra wire. Thanks for the help. |
#4 | |
Drilled the cover, installed the stalk with the wire, did a road test and it's not working. I definitely need help here guys. What do you think, the 06-08 method? Looks like this is going to be a learning experience for the people with Yaris bought in Mexico. |
#5 | |
Can you take a measurement on the wire that goes to the ECM pin. With the ignition on and none of the stalk switches pressed, it should read +12V.
#6 | |
This are the connections under my steering wheel. there's no blue and no brown wire. ![]() This is my cluster showing the cc icons. ![]() So I have to run the wire from which hole in the connector? What else do I have to do, I already drilled the cover, plugged the stalk wire and bolted the OEM stalk. I was really hoping my '10 AT had all the wires in place. Not at all. |
#7 | |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 12:59 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 11:12 PM |
