Old 11-12-2011, 05:43 PM   #1
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
I would use a 2" hole cutter with a drill and cut through the under panel.
Old 11-12-2011, 07:06 PM   #2
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
This.
I did this in mine and I would recommend removing the entire door panel. Leave the top cover piece on when you drill through. You should be fine with the clips. I even mounted mine further towards the front and it was fine.
tweeters in door centrysis In Car Entertainment + Electronics (audio / video / alarm) 10 06-04-2010 11:01 AM
Best place to mount tweeters in the LB? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 20 01-18-2010 11:45 PM
Powering/Installing Tweeters? eii In Car Entertainment + Electronics (audio / video / alarm) 1 01-12-2010 09:00 PM
A-Pillar gauge pods that can fit tweeters? IsLNdbOi In Car Entertainment + Electronics (audio / video / alarm) 9 11-23-2008 02:25 PM
6.5" Subs in rear? Mounting depth Yucky Darren In Car Entertainment + Electronics (audio / video / alarm) 5 04-19-2007 02:46 PM
