Old 12-01-2011, 08:08 PM   #1
SimTronik
Machinist
Drives: Yaris sedan 2010
So i'm missing: Connector D3 Pins, quantity 2 (82998-12870) and Lower Steering wheel Boss (cover) (with the hole already in it for the cruise stalk {If you
don’t wish to drill the exiting one}):45184-52130-B0 and ¼” Ring terminal for 18-22 AWG wire (if required to terminate added D3 ground pin).
If i get it right...
I own a Yaris sedan 2010 w/ power.
(ok ok i could drill the existing steering)
SimTronik is offline   Reply With Quote
Old 12-01-2011, 08:28 PM   #2
Did you verify that the D3 pins are not present? A 2010 Sedan with power should have them.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
Can we do this? (aka The DIY Cruise Control Thread) mrbond DIY / Maintenance / Service 502 07-22-2017 02:57 PM
This is pretty frikken stupid - Yaris '07 LB auto cruise control firemachine69 DIY / Maintenance / Service 10 07-20-2010 08:09 AM
