#37 |
Your provider could have accidentally mixed in a RHD box with your shipment by mistake. Honest mistake I think.
*edit: this post is meant for Garm |
#38 |
I have the G1 projectors, which provide lower light output than the G3's. Here is what they look like with the provided 6000k bulbs.
At start up and warming up ![]() ![]() ![]() Cutoff (yes, I purposely aimed it so that it looks like stairs going up towards the right; I'm assuming yours looks like it would be to the left if you "stacked" the cutoffs?). ![]() ![]() Comparing it to a stock 08 or 09 Mazda6 (stock HIDs) ![]() The Mazda6's cutoff ![]()
#39 |
Pirate Yaaaaris
Drives: '00 Toyota Celica GTS 6MT Join Date: Aug 2009
Ok. Please let me know what you find out. Either here or by e-mail.
This is the box, just in case. The orientation of the cut offs on the box is correct: ![]() ![]() ![]() -C
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. |
#40 |
If your cutoff looks like the picture on the box, then you have the correct, LHD cutoff.
#41 |
Pirate Yaaaaris
Kaotic:
Yeah, my 'stairs' go the other way. And I got flashed a ton from oncoming drivers on just a short drive down to the gas station and back. I then lowered the left a little and the right is raised nearly all the way up. Even if I get the correct aim and all, I suppose part of it is that it just takes getting used to. I've never had a car with HIDs before and the division between light and darkness is much sharper than with traditional halogens where it kinda fades to darkness. Edit: It doesn't. My cut off picture is a little further up the thread. Even Brian said that mine look like RHD cutoffs. -C
#42 |
Ah, I missed that post, but yes, those are definitely RHD cutoffs. You'll get flashed no matter what if you aim them to have usable light.
#43 | |
#44 |
My projectors have the same cutoff....but it looks to me like they're sitting crooked in the headlights...the base gap of the halo ring should be pointing down...
The setup illuminates the right side of the road more at night. The manufacturers stopped including sealant last year as they were getting hassled by customs
#45 |
Pirate Yaaaaris
I looked into the flare problem earlier tonight here at work since I had an area with a building wall to see where light was being thrown and it appears that Yaris2010 was right. The reflectors bounce a portion of light to the outsides if they are left unpainted. I only have my cell camera on me but i tried capturing the reflection causing the flare.
![]() ![]() ![]() Notice the speed limit sign ahead on the left illuminated, yet the stop sign closer and to the right remains fairly dark.
Georgia Bulldogs! ![]() '09 Yaris LB 5MT Sold. Last edited by SAV912; 01-10-2012 at 10:17 PM. |
#46 |
Not quite a noob
Drives: e46 325 Join Date: Jul 2009
Is there any way you can rotate the entire projector the 20 degrees or so required to manuall make it kick up on the right instead?
#47 |
Pirate Yaaaaris
It might be possible with work, but then the halo would be off. I'm not sure just rotating it would fix it alone. It's worth a try I suppose.
#48 |
Not quite a noob
I wouldn't personally mind the halo being off, having it at a slight angle would look pretty cool I think
#49 |
That's odd since the reflector bowl is designed for LHD cars so it should just throw the beam back towards the right????
#50 |
No. The reflector bowl should have no effect on the light if using a projector. The projector should control all of the light output by itself. If the light coming out of the projector is hitting the reflector bowl then the projector may need to be moved out more to allow it to do its job.
#51 | |
Pirate Yaaaaris
I'm guessing it's really bad on the right projector because the kick up is to the left instead of to the right like it should be, while also reflecting off that side of the bowl and getting thrown back to the right. Hence my problem with the ground directly in front of the car to the right being lit.
#52 |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
the halo "connector" or "dead spot" on both of mine are off by ~20 degree.
and i believe this calls for a i told u so? lol, jksjks. as for your concern with the speed sign being lit further away then the stop sign, the stop sign is higher and closer to u then the speed sign, if ur cut off is at hood level things dirrectly infront of u will no be illuminated if higher then ur hood, the further out u go the more light bleeding u get and the more the slight angle of ur car will be amplified per mesurement of distance away. the light that bleeds up at that distance will not be blinding for other drivers.
#53 |
to me, it looks like both of your projectors need to be rotated clockwise a bit....which should sort out your rhd lookalike setup
here are how mine look ![]() ![]() here is the cutoff on mine...
#54 | |
| Sedan HID Projector Retrofit Headlights | !yaris! | Cosmetic Modifications (Exterior/Interior) | 10 | 10-26-2017 02:31 AM |
| Retrofit & fogs | big lo | Cosmetic Modifications (Exterior/Interior) | 0 | 06-19-2010 09:13 PM |
| To put on PnP HID kit without retrofit, Yes or No? | mr.white_hb | Cosmetic Modifications (Exterior/Interior) | 3 | 09-20-2009 08:43 PM |
| Retrofit Question | ChinoCharles | Cosmetic Modifications (Exterior/Interior) | 19 | 05-13-2009 06:20 PM |
| Sam's 2nd H.I.D. retrofit | sam07yaris | Photo-Video-Media Gallery | 22 | 08-31-2007 04:02 AM |
