Old 02-05-2012, 02:40 AM   #1
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
0101 is usually a vacuum leak of some sort or the MAF. Could be that the MAF is sitting too low or too high or is it possible that you put it back on during installation backwards? Did you clear the codes to see how long before it came back?
Old 02-05-2012, 04:09 AM   #2
bugg_master
Drives: yaris sedan type s
i looked online to see how to reset the check engine light but the online thing that mainly showed online was reseting the maintenance light. i also tried taking out the fuse but its still showing....i screwed on the maf in all the way but i havent tried rotating it...i'll turn it around tomorrow and well see if the lights still there. but how could the maf be either too high or too low?
bugg_master is offline   Reply With Quote
Differntial diagnosis for the check engine light yaris sedan dante2086 DIY / Maintenance / Service 1 12-18-2010 09:04 AM
Check engine light Mr Yarisman Performance Modifications 7 10-24-2009 11:10 PM
ODB2 Check engine code reader Arkhangel Performance Modifications 11 02-25-2009 04:13 AM
Nitto Mid-Pipe Check Engine Light fix Jerkratt Performance Modifications 77 12-01-2008 07:23 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
