Old 03-21-2012, 05:46 PM   #1
bugg_master
Drives: yaris sedan type s
Check the ECU-B fuse in the under hood fuse panel.
CT the high beam icon does not come on but the low beam icon works,I double checked it again, does this change anything?
bugg_master is offline   Reply With Quote
Old 03-21-2012, 06:51 PM   #2
The high beam indicator is separate from the headlights on indicator. The headlights on one is driven by the control side of the circuit and the high beam indicator is driven by power flowing through the bulbs, so if both bulbs were bad, that would be one possible explanation.
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
Sedan HID Projector Retrofit Headlights !yaris! Cosmetic Modifications (Exterior/Interior) 10 10-26-2017 02:31 AM
2010 yaris Projector headlights yaris2010RS Items for Sale by private party 9 01-09-2012 05:31 PM
Headlights Dpudg General Yaris / Vitz Discussion 5 09-04-2011 03:18 PM
Best Aftermarket Headlights MadMax Cosmetic Modifications (Exterior/Interior) 3 06-04-2009 06:50 PM
