Old 04-13-2012, 09:00 PM   #13
Originally Posted by Strider199 View Post
So after work I tried to hook up the converter again.
I spliced in the running lights right to a running light bulb which I checked with my tester. Plugged in the trailer and the running lights where on.
I then spliced into the left signal light and tried that. Worked great.
I then spliced into the right turn signal and it worked great.
I then spliced into the brake wire at the bulb and had my son push the brake pedal. It worked great.
Thought I was all set but then, I put on the 4 ways. The rear trailer lights flashed but they were dim. I stopped that and turned on the running lights again, nothing. I tried the left signal, both signal lights flashed dim. I tried the brakes, nothing.
I SHUT IT DOWN.
Tomorrow I will pick up a powered trailer light converter and see how that works.
Why are they making the wiring in almost every car so frustrating these days?????????
Ahhh, Looking at the 2012 EWDs I see the issue - The flasher functionality has been coalesced into the combination meter, instead of being a separate flasher relay assembly.
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
