Old 04-13-2012, 08:50 PM   #12
Strider199
Strider199's Avatar
Drives: Black 2012 Yaris 3door 5speed
So after work I tried to hook up the converter again.
I spliced in the running lights right to a running light bulb which I checked with my tester. Plugged in the trailer and the running lights where on.
I then spliced into the left signal light and tried that. Worked great.
I then spliced into the right turn signal and it worked great.
I then spliced into the brake wire at the bulb and had my son push the brake pedal. It worked great.
Thought I was all set but then, I put on the 4 ways. The rear trailer lights flashed but they were dim. I stopped that and turned on the running lights again, nothing. I tried the left signal, both signal lights flashed dim. I tried the brakes, nothing.
I SHUT IT DOWN.
Tomorrow I will pick up a powered trailer light converter and see how that works.
Why are they making the wiring in almost every car so frustrating these days?????????
New to the Toyota World, be nice.
Strider199 is offline   Reply With Quote
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
