Old 04-10-2012, 08:25 PM   #8
Originally Posted by Strider199 View Post
The trailer lights are bulb. Duel elements, running lights and brake/signal.
Bulbs definitely draw more current, but unless someone installed some crazy wattage bulbs, the converter should have taken care of the issue. Can you take some resistance measurements on the trailer connector to see what you measure for each of the three pins to ground (assuming you have a 4 wire connector)?
Also, to verify your wiring, one the 2012 tail light connectors:
Taillight - Green wire on either right or left
Stop - Light blue wire on either
Right Turn - Sky blue wire
Left turn - Yellow wire
Ground - White/black (or bare metal bolt connection)
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 08:08 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
