Old 05-04-2012, 08:40 AM   #1
ijose 845
ijose 845's Avatar
Drives: 07 Toyota Yaris
dont they come pre wired with the yaris? Aint it just plug and play?
Angry Bird Crew #1
ijose 845 is offline   Reply With Quote
Old 05-04-2012, 09:00 AM   #2
The question was how to re-wire the OEM ones.
To answer his other questions sent in PM:
The connector pictured is located under the steering column cover at the base of the headlight stalk. Search for my "headlights off with the key" DIY for a pictorial guide to getting the cover off.
The second question was explaining the wiring more. You are simply going to cut the wire, far enough away from the connector to give you a 2 inch or so piece of wire attached to the connector to work with. That side of the cut you will attach to the wire in position 7. A "tap splice" connector, available at any auto parts store, is the easiest way to do so.
The other side of the wire you just need to cover with tape or a butt splice
Old 05-04-2012, 08:17 PM   #3
ggrieco
Drives: 2008 yaris aero
Got it, will let you know how things turn out.
Thanks,Gary
ggrieco is offline   Reply With Quote
Fog lights, or parking lights stopped working sylvermagyk DIY / Maintenance / Service 4 03-24-2011 05:13 PM
How to turn on the running lights and fog lights @ same timewhile/headlights off ...? Moratiya DIY / Maintenance / Service 8 12-11-2010 06:40 PM
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
