![]() ![]() Drives: 2007 yaris sedan Join Date: Aug 2011
This mod makes the headlights turn off when the ignition is turned off
Has anyone tried this mod. If yes are you experiencing any problems.
http://www.yarisworld.com/forums/sho...gnition+turned Thanks, PatM Last edited by patm; 05-06-2012 at 03:40 PM. |
that's right I went there
Drives: '08 Blazin' Blue,'10 Dark Red Join Date: Oct 2008
do u mean if all the lights are on (i.e. headlights and tail lights)? I don't belive anyone has.....be cool though
Mods : 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals. suggestions always welcome
there is a mod that makes the headlights turn off when the ignition is turned off on this website
http://www.yarisworld.com/forums/sho...gnition+turned Has anyone tried it. |
#4 | |
![]() ![]() Drives: Toyota Yaris LE HB 2008 Join Date: Apr 2012
I'm not concerned of the headlights when the ignition is turned off, but I am concerned of turning the headlights off on a sunny day and turn them on when at dark.
On my Mazda Protege 2002, I only need to lift a click on the handbrake and I can drive without headlights when I want. Is that possible with a Yaris ? |
#6 | |
#7 | |
Only Happy When it Rains
Did it about 6 months after I had the car. Not a problem at all.
I will say though in canada it is a law you must havs drl's. At least I am almost positive I have read canadian members saying that.
Colin Chapman disciple |
Ok great for deleting the DRLs...
but will I need to reconnect the DRL relay if I want to drive at dark ??? I need to understand before doing the surgery that if I remove the DRL relay, I will be able to do something other than reconnect the relay to drive by night. Thanks ! |
#10 | |
![]() All you'd be doing is disabling the daytime running lights, everything else would be like usual, if you want your lights on, turn them on.
#11 | |
![]() ![]() ![]() Drives: '08 5-door Join Date: Apr 2009
| Dashboard lights turn off when I turn use headlights | patate15 | DIY / Maintenance / Service | 7 | 07-05-2020 03:05 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| AC makes a rattling noise when turned on. | gabriel2012 | DIY / Maintenance / Service | 8 | 07-12-2011 06:03 PM |
| Will local bay area members please stand up! | YarisSedan | California | 264 | 07-28-2009 11:53 PM |
| 2007 Yaris Sedan S Ignition won't turn | koharegistrar1 | DIY / Maintenance / Service | 7 | 12-24-2008 08:34 AM |
