2ZR swap. DO IT! Ask how!
One other solution to the side-mount TB is to use a tapered plenum:
![]() As far as runner length, all of the material that I have read insists that longer runners = low end power and vice versa. This is all based on the Helmholtz resonator theory. If you look at the first equation (relax, you don't have to solve it) you can see that the mass of air in the neck is in the denominator, meaning that larger masses of air (longer runners) will decrease the resonant frequency (RPMs). Increasing the cross sectional area will increase the frequency, as well as have a slowing effect on air flow velocity in the runners. The variables for the 'cavity' refer to the cylinder, not the plenum. tl;dr - science says long runner = low rpm boost. Unless this article has empirical evidence to back up their claims, treat it as snake oil. |
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
