Old 06-24-2012, 11:14 PM   #1
new-yaris-owner
Drives: Toyota Yaris LE HB 2008
Ok great for deleting the DRLs...
but will I need to reconnect the DRL relay if I want to drive at dark ???
I need to understand before doing the surgery that if I remove the DRL relay, I will be able to do something other than reconnect the relay to drive by night.
Thanks !
new-yaris-owner is offline   Reply With Quote
Old 06-24-2012, 11:25 PM   #2
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Thanks !
No, just turn your lights on when it's dark out!
All you'd be doing is disabling the daytime running lights, everything else would be like usual, if you want your lights on, turn them on.
Dashboard lights turn off when I turn use headlights patate15 DIY / Maintenance / Service 7 07-05-2020 03:05 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
AC makes a rattling noise when turned on. gabriel2012 DIY / Maintenance / Service 8 07-12-2011 06:03 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
2007 Yaris Sedan S Ignition won't turn koharegistrar1 DIY / Maintenance / Service 7 12-24-2008 08:34 AM
