toyota
im pretty sure just the low pressure switch is not working, high pressure should still shut off the compressor during WOT.. im still leaning into checking the ambient sersor as well..
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!! "Horsepower is how fast you hit the object. Torque is how far you move that object.." |
It is a single pressure transducer that feeds the pressure reading to the AC ECU, which then decides if it is low, high, or just right.
toyota
so ur saying by jumping the low pressure switch harness thats automatically jumping the high pressure as well?? men this is getting too complicated.. appreciate the input though..
There is just one sensor (not a switch or switches, but a device that changes resistance based on pressure). That is why the two resistors, rather than jumpers are required to bypass it.
| DIY A/C low pressure line insulation | syntax | Middle East | 291 | 06-17-2021 02:05 AM |
| Low Tire Pressure Sensor | DebbyM46227 | General Yaris / Vitz Discussion | 24 | 10-18-2010 10:02 AM |
| Intermittent low oil pressure light. | Inspector14 | DIY / Maintenance / Service | 23 | 03-29-2010 01:46 PM |
| screw more psi in the tires. | thebarber | Fuel Economy Forum | 43 | 05-04-2009 04:46 PM |
