Old 03-22-2007, 05:49 PM   #1
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
Probably Motul - but is hard to find here in Canada
Otherwise Canadian Tire sells Red Line, another good choice
I personally don't trust that much Amsoil. They publicize a lot on internet, "best synthetic oil" on Google returns dozens of sites all on Amsoil . Any of those sites are that kind of stuff saying Amsoil is the best... ok...
Mobil 1, Mobil 1 Extended Performance and Castrol Syntec are only intended to give better start-up on cold days, not for extended oil change intervals
hystria is offline   Reply With Quote
Old 03-22-2007, 07:30 PM   #2
Pavel Olavich
Drives: 2007 Yaris LB
You're wrong...it says right on the label "15,000 Miles".
Pavel Olavich is offline   Reply With Quote
Old 03-23-2007, 06:41 PM   #3
hystria
hystria's Avatar
I know I'm wrong that's what I'm using right now, the Mobil 1 Extended Performance + K&N filter, it has 2000 miles and the oil got quite dark, now tell me If a real synthetic would do so, anyway, it's the last time I'm using a pseudo synthetic. if one needs to spend more money at least buy real synthetics, i.e. Motul, Red Line or Amsoil
Old 03-23-2007, 06:43 PM   #4
spkrman
Drives: 1
very many tests wouldn't agree :)
Old 03-25-2007, 12:10 AM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
well I change my oil every 5000 miles I have used mobile one 5-30 full synth and amsoil 5-20 full synth and now currently running 0-20 mobile one full syth, and after every oil change oil has still look a good golden color, I have always used Champ brand filters except this last time I gave fram a try
Old 03-25-2007, 03:26 AM   #6
Pavel Olavich
Going against the Toyota manual means your 0-20 oil could screw up your engine...why are you doing this?????
And chaning the Synthetic oil every 5,000 miles seems very foolish, and wasteful of your $$, and misses the entire point of using synthetic.
Don't buy this dillusion of thinking that just because the oil color changes, that it needs to be replace...this is based on dillusion void of facts, friend.
Save your $$....do it every 7,500 or 10,000 miles, and use the correct viscosity as dictated by the owners manual.
Old 03-25-2007, 07:57 AM   #7
Black Yaris
der Zeck
Hey guy there is a Toyota TSB to increase gas mileage for the 1NZ motor use 5-20 or 0-20 synthetic oil
and god forbid somthing were to happen to this engine I do need a proof the oil was changed every 5000 miles synthectic or not, so untill the warranty is up 5000 miles it is, after that I will go more than that...
Old 03-30-2007, 12:42 PM   #8
Pavel Olavich
Would you please send me/us all a link of that TSB? I would greatly appreciate it. If there exists such a TSB, then I too would be very interested in using a lighter oil for better MPG...
Old 03-25-2007, 11:34 AM   #9
hystria
hystria's Avatar
that's interesting to know, do you run on 89 or higher gasoline ?
Old 03-26-2007, 02:54 AM   #10
Pavel Olavich
Running octane higher then 87 is just wasting money, and doing this actually makes the car run UNDER powered, as the combustion is RETARDED...for most power, use octane 87, as the Toyota manual dictates....save your money....more octane means LESS POWER...especially for very small engines having low compression....
Old 03-28-2007, 08:34 PM   #11
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
I agree with Pavel that running higher octane will waste money but no need to get worked up. I have to say though, the Yaris has pretty decent compression for an econocar. If the damn thing would only rev higher!!
I use Redline Full Syn 5-30 with a Mobil 1 or K&N high flow filter. These two filters are made by the same manufacturer and are good quality. And Redline is just the biz.
Galavoxx is offline   Reply With Quote
Old 03-29-2007, 08:58 PM   #12
Black Yaris
der Zeck
yes I run shell 89 oct at min
Old 03-29-2007, 09:56 PM   #13
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
[/threadjack] (again)
High octane rating only determines at what point the fuel will combust. A high octane fuel is to prevent a thing called "Predetonation" from occurring.
Predetonation is not a term you ussually hear in parking lots full of kids showing off their cars, ussually it is used at the dragstrip listening to guys talk about their 400+HP 4cyl boosted cars.
Predetonation is what happens when due to pressure in the combustion chamber the fuel ignites prematurely before the spark plug triggers. This is a very bad thing, because if the number 1 cyl predetonates, it goes against the crankshaft being turned by the pistons that are firing in the correct order with their spark plugs.
The force inside a cylinder chamber becomes increasingly higher when you try to force 20 PSI of boost into it. When the piston goes on what is called the compression stroke(the stroke where it mashes the mixture of air and gasoline together in preporation to be ignited) the pressure can sometimes be enough to cause the mixture to explode.
High octane rated fuel is used to prevent the gasoline and air mixture from blowing up before it is supposed to. The only benifit to using high octane fuel on a car that was designed for 87 octane piss water is that it sometimes burns cleaner because some gas stations may put more adatives in it and sometimes it is a slightly better grade of fuel.
If you ever get boosted or change the compression to something radical(say 14 to 1) then look into 89 octane, untill then, feel free to waste your cash on the gas that costs 30 cents more a gallon.
Old 03-25-2007, 03:22 AM   #14
Pavel Olavich
So it got dark....now you're a chemist
So what...it got dark...this does not mean it is not working as expected.
Relax and stay with it through 10,000 miles....you'll be ok and so will your engine.
Why do you call it "pseudo"? It's the real deal, and like mineral oil, it too will change color with use...this is okay!!
Old 03-29-2007, 11:53 PM   #15
BailOut
Steals terrorist's lunch
BailOut's Avatar
It sure does, and K&N says their oil filter can go with that, so that's exactly what I'm doing for both our vehicles.
I plan to change the oil right around the time we re-register the cars annually.
- Brian
Share the Road
best synthetic oil and m/t oil?? doodoo DIY / Maintenance / Service 122 04-03-2017 08:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 02:56 AM
My first oil change RogueYaris DIY / Maintenance / Service 41 02-07-2007 07:41 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
