Old 07-22-2012, 12:08 PM   #11
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Originally Posted by CrankyOldMan View Post
Was it the bolt hole alignment, or perimeter clearance?
It was perimeter clearances. The top of the flange needs to be milled down 1mm to clear the stock fuel rail supports. It's really close, as I was able to drop in the flange easily just by slightly loosening the fuel rail bolts. There is a cylindrical sensor close on the left side so I filed a semicircle to clear it. Also at the center of the fuel rail there's a part underneath it which also needed a semicircle filed to clear.
They were minor and corrected with a file. The goal is to make the flange simply drop in.
How are you doing on yours? I hope that sharing the details of the process will help to move your manifold along.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
