#613 |
more on "wrecking" the motor.
It should be pointed out also that you have no way of knowing the long term affects of your manifold on your motor. In fact, you could be feeding one cylinder too much air, or not enough, with a dramatic decrease in engine longevity. If you want to know, I suggest a look at your plugs now and 10,000 miles from now, and a compression test would be a good idea as well. All stuff you can do yourself at no cost.
#614 | |
#615 |
0-60 in slow
I'll let you know this the Pikes Peak racers don't use air filters and that's back when they ran on dirt. I know this because I had a 900hp TRD 503e engine sitting 2 feet away from me for 2 years.
That was a cool motor ITB"s with a common plenum for the turbo's only bad thing was once the head was bolted on the block couldn't be reused. |
#616 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
#617 |
0-60 in slow
I don't wanna hijack much but this was the explanation that was given to me by a TRD engineer.
When the heads are bolted onto the block the block would distort, and when the heads would be unbolted the block would remain distorted, and since its a race engine it was all built to a specific tolerance and it couldn't be machined or it would go out of spec. You also have to remember these engines were build for IMSA racing so they only need to last for a 24hr race and then they would be replaced. Those motors could make an insane amount of power from a 2.3l reliably but for some reason they have turbo failure issues so you either get lucky or you have a motor that cooks after a short period of time. In case you were wondering they make 900+hp at 31psi only problem is they sound terrible not a nice sounding engine. |
#618 | |
play every day
The first pulls were done with the Blox filter, so my common sense tells me that the second ones will also be done with the same filter. I'm still sticking with the manifold being the only change. USPS tracking had the silicone connector arriving yesterday, so I'll be headed to the Post Office tomorrow after work to see what's up.
#619 | |
play every day
It's one thing I really like about this particular design in that it does not possess the inherent runner inequities of the typical log style manifolds which are fed from one end... ![]() ...because all 4 runners share exactly the same relationship to the throttle body. I'm also counting on the fact that this design had already been produced for 4 years and ran on tens of thousands of Corollas over a time span of as much as 14 years. Last edited by tooter; 08-16-2012 at 10:32 PM. |
#620 |
play every day
#621 | |
![]() ![]() Drives: Yaris '06 Join Date: Apr 2011
That will be a good baseline to see if just changing the intake manifold alone will account for any gains/loss
#622 | |
play every day
That's really fascinating information namer. I'm counting on my engine lasting longer than 24 hours. ![]() That Pikes Peak racing engine produced .39 horsepower per cubic centimeter, or over 5.5 times that of a stock Yaris which produces just .07 horsepower per cubic centimeter. ![]() Here's Rod Millen at Pikes Peak... http://www.youtube.com/watch?v=soQsCyr0hTw |
#623 | |
0-60 in slow
but those are not for the internet.
#624 | |
play every day
#625 | |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I dont see what is the issue of selling just flanges (just like we sell all the same componants we use in our kits), you can still make money off of them. I weld my own stuff, its what I do & i already have a manifold to cut up. ![]() If not, this has been a very disappointing thread. When I pop my hood, I like being able to say...i fabricated that, I made that, etc. Obviously you designed & made the flanges, just like I did not make the mufflers I use (i have made my own mufflers & resonators before however) ![]() ![]()
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
#626 |
play every day
Yes, that's correct malibu. I'm sorry if you had misunderstood. I said that I'm going to sell both... including complete bolt on manifolds. I already have five, four to sell to help cover the money I put into this project, and one for my own car. Man, if you really were in Malibu, I'd be happy to pay you to do the welding, but the cost of freight back and forth would cut too deep.
#627 | |
#628 | |
(BTW, I may go for one of these myself)
#629 | ||
play every day
Sure, Garm. ![]() Post #584 Quote:
#630 | |
play every day
I realize that (depending on the dyno results) this will likely not be just a one-off private party sale, and that it crosses the borderline into being a commercial venture. Can you let me know how much you charge for the privelege of selling here so that I can factor that cost into the selling price of the kits and manifolds? Thanks in advance.
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
