![]() ![]() ![]() Drives: 2007 Orange Yaris Hb 3Drs Join Date: Dec 2006
I know I'm wrong
that's what I'm using right now, the Mobil 1 Extended Performance + K&N filter, it has 2000 miles and the oil got quite dark, now tell me If a real synthetic would do so, anyway, it's the last time I'm using a pseudo synthetic. if one needs to spend more money at least buy real synthetics, i.e. Motul, Red Line or Amsoil
#2 | |
#3 | |
der Zeck
#4 | |
Drives: 2007 Yaris LB Join Date: Mar 2007
And chaning the Synthetic oil every 5,000 miles seems very foolish, and wasteful of your $$, and misses the entire point of using synthetic. Don't buy this dillusion of thinking that just because the oil color changes, that it needs to be replace...this is based on dillusion void of facts, friend. Save your $$....do it every 7,500 or 10,000 miles, and use the correct viscosity as dictated by the owners manual. |
#5 | |
der Zeck
and god forbid somthing were to happen to this engine I do need a proof the oil was changed every 5000 miles synthectic or not, so untill the warranty is up 5000 miles it is, after that I will go more than that... |
#6 | |
Would you please send me/us all a link of that TSB? I would greatly appreciate it. If there exists such a TSB, then I too would be very interested in using a lighter oil for better MPG... |
#7 | |
Running octane higher then 87 is just wasting money, and doing this actually makes the car run UNDER powered, as the combustion is RETARDED...for most power, use octane 87, as the Toyota manual dictates....save your money....more octane means LESS POWER...especially for very small engines having low compression....
I agree with Pavel that running higher octane will waste money but no need to get worked up. I have to say though, the Yaris has pretty decent compression for an econocar. If the damn thing would only rev higher!!
I use Redline Full Syn 5-30 with a Mobil 1 or K&N high flow filter. These two filters are made by the same manufacturer and are good quality. And Redline is just the biz. |
der Zeck
yes I run shell 89 oct at min
The Hated One
Drives: 07 White Manual Sedan Join Date: Sep 2006
[/threadjack] (again)
High octane rating only determines at what point the fuel will combust. A high octane fuel is to prevent a thing called "Predetonation" from occurring. Predetonation is not a term you ussually hear in parking lots full of kids showing off their cars, ussually it is used at the dragstrip listening to guys talk about their 400+HP 4cyl boosted cars. Predetonation is what happens when due to pressure in the combustion chamber the fuel ignites prematurely before the spark plug triggers. This is a very bad thing, because if the number 1 cyl predetonates, it goes against the crankshaft being turned by the pistons that are firing in the correct order with their spark plugs. The force inside a cylinder chamber becomes increasingly higher when you try to force 20 PSI of boost into it. When the piston goes on what is called the compression stroke(the stroke where it mashes the mixture of air and gasoline together in preporation to be ignited) the pressure can sometimes be enough to cause the mixture to explode. High octane rated fuel is used to prevent the gasoline and air mixture from blowing up before it is supposed to. The only benifit to using high octane fuel on a car that was designed for 87 octane piss water is that it sometimes burns cleaner because some gas stations may put more adatives in it and sometimes it is a slightly better grade of fuel. If you ever get boosted or change the compression to something radical(say 14 to 1) then look into 89 octane, untill then, feel free to waste your cash on the gas that costs 30 cents more a gallon.
#12 | |
der Zeck
...even if it runs better and gets better mileage, use of a higher octane that your car does not need can lead to carbon build up in the combustion chamber. This is especially true over the life of the engine. What may run good now, may have some issues after 100k miles. You want to make sure the fuel in the combustion chamber burns off quickly and completely. Without the added compression to assist in the process, 87 octane burns hotter and faster than 91. So your car may run better on 91 and get better gas miles now but this doesn't mean it will be better over the life of the engine. Just my 2 cents.
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
30 cents more a gallon?? I have given this thought: it's 10 cents a gallon more for "plus", and so, ten gallons equals ONE dollar. The Yaris sedan holds 11 gallons. So, a dollar a full tank? Worth it, for the added cleaning agents' power. Can you say preventive maintenance??
#15 | |
So what...it got dark...this does not mean it is not working as expected. Relax and stay with it through 10,000 miles....you'll be ok and so will your engine. Why do you call it "pseudo"? It's the real deal, and like mineral oil, it too will change color with use...this is okay!! |
| best synthetic oil and m/t oil?? | doodoo | DIY / Maintenance / Service | 122 | 04-03-2017 08:43 PM |
| Help with oil change specs | autophile | DIY / Maintenance / Service | 31 | 04-25-2011 09:22 PM |
| metal particles in oil | 007 hatch | DIY / Maintenance / Service | 9 | 06-22-2007 02:56 AM |
| My first oil change | RogueYaris | DIY / Maintenance / Service | 41 | 02-07-2007 07:41 AM |
