#739 |
play every day
The tooter results came in at +1 -1
And I think this was the latest list of guesses: malibu +4 -6 Tooter +2 -3 Mazilla +1,000 Garm -5 -5 Anomaly +1 -3 Ljming -3 +3 BEEF +3 -2 Goldeenoh +5 -3 Goliath 0 0 tk-421 +4 -3 Yoda +4 +3 Jason -12 -18 packet +5 +3 Maitre +2 +4 Jeff -3HP -10TQ Bluevitz-RS +4hp +6Tq Scubaru Steve 0hp +10Tq Flipper_1938 +6hp +4 ft lbs Viperoni +2 -5 enviri +3hp 0tq xnamerxx -10hp -10tq CTScott -2hp +4tq eTiMaGo 0 0 Billiam ![]() + 1,000,000 Looks like 4 people were a total of 2 digits off :Anomaly Goliath enviri eTiMaGo Maybe we need to do a run off dyno.
#740 |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
Great read. I applaud the effort put into the manifold and testing it. I wouldn't be dissapointed at all, Ive seen reputable companies produce manifolds which proved power loss much greater. You have the right design aspects in your manifold design for the goals you had in mind. If I were to guess, a header will compliment that manifold simply because the volumetric efficiency of the intake has increased so much. You may not have a gain now because your setup is ''lopsided'', hiding the potential of the manifold.
As far as dyno conditions, that sheet clearly states the numbers are SAE corrected... which means temperatures and barametric pressure is accounted for. ( you can dyno on a 30 degree day, and on a 90 degree day, the numbers should theoretically be the same if SAE corrected). VVT I on our cars learn, and change according to driving habit. I put my car on our dyno once with no changes, It made 28ft. lbs more torque, 6 less hp.........no changes. So I would deem your results inconclusive until you switch the manifold right on the dyno.
Ptuning.com |
#741 |
well, it's a somewhat underwhelming result for the amount of work that went into it, but on the bright side, you haven't really lost power... and like others have said, it may well have major advantages once boost comes into play... So what are you waiting for, tooter? grab that turbo kit! :D
#742 | ||||
play every day
![]() Considering that this was the very first attempt of a total amateur, the results weren't all that bad. I'm going to see if I can do better now. Quote:
BLOX velocity stack air filter Weapon R short ram intake Weapon R 4-2-1 header Micro Image center exit axle back exhaust tooter manifold ![]() Quote:
#743 | ||
play every day
I'm going to stay on the normally aspirated path. Even though the dyno runs reveal the manifold's shortcomings at full throttle, in normal partial throttle low rpm everyday driving conditions it works really good.
#744 |
Disappointing numbers...but at least you tried. For that, I applaud you.
#745 | |
Depot Damager
Drives: '08 Liftback Join Date: Jul 2012
2008 Yaris Liftback - Bought in '12 with 80k Sold in '17 with 180k Bought back in '20 with 270k Currently collecting parts for the 2zr swap |
#746 | |
I don't think 'driving style' can change the maximum power output on the dyno anyway, but it might change the curve some.
#747 |
play every day
#748 |
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
Time to have the shop make you a adapter for a corolla TB :)
I got my corolla TB yesterday. I'm going to buy an xB weapon R intake manifold and have the TB flange modified to fit it. |
#749 |
"Know it all"
Drives: Lancia Delta Integrale Join Date: Jan 2012
Why not purchase the Micro Image manifold with the 1ZZ TB flange already on it?
www.microimageonline.com |
#750 |
#751 |
"Know it all"
Very soon, we have a prototype to dyno and if all looks good we'll begin production.
#752 | |
Takes corners too fast!
Drives: Absolute Red 2009 Yaris HB Join Date: Apr 2012
mods:15''Drag DR21 w/Nitto NeoGen 205/50R15, Tanabe DF210 lowering springs 1.6/1.8, TRD Rear Sway Bar, Tanabe Front Sway Bar, Micro Image Short Throw Shift Kit (both in and under), 8.64lbs flywheel, F1 Stage 4 Clutch, AEM Cold Air Intake (Red), Megan Racing Header, DC Sports Axle Back Exhaust, Micro Image Crank Pulley, NST lite Alternator Pulley, ARP Manifold Stud Kit,Tanabe Front Strut Tower Brace, ScanGuage II, Micro Image Silicone Radiator Hose Kit (Red), NRG Carbon Fiber Shift Knob (round), 2009-2011 Toyota Yaris Liftback Foglight kit, NRG Grounding Kit (Red), Hella Horns(Red),CF Hood |
#753 |
tooter, once you get a bigger resonator-to-axleback exhaust piece, youll likely feel better gains all over
#754 |
play every day
#755 |
It bolts right on, it has a little larger throat.
#756 |
It has a bigger opening, nothing more. same bolt pattern, it's a direct bolt on. You'd just need a bigger opening on the adapter
| homemade intake manifold | ttr125fan09 | Performance Modifications | 1 | 02-17-2012 01:09 AM |
| Custom Intake Manifold + Direct Port Nitrous | blacksandiegovitz | Performance Modifications | 9 | 04-21-2010 07:05 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| turbo manifold build... | joey1320 | Forced Induction Forum | 4 | 06-30-2007 02:26 PM |
