^ At WOT it won't matter, there isn't any ECU "learning" in open loop.
It does learn your "style" etc. for regular driving/partial throttle/cruising; that's what we've been testing this week.
oh ok :)
![]() Drives: Yaris 1.3 07 Join Date: Oct 2011
looks great ;)
it is 2" inches isn't it ?? ... waiting for the dyno |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
Will this fit with the aFe intake? $$?
^ We don't know the price yet, and we haven't tested it with any aftermarket intakes. What you see in the thread is everything we know and have done so far.
If the dyno shows some power gains, we will further refine the design if we can to fit the stock or aftermarket intakes to the manifold.
![]() ![]() Drives: 2007 3dr hb 5sp Join Date: May 2012
Those J Bend tubes are super sexy. sure beat the plastic composite look.
![]() ![]() Drives: 2008 Yaris HB MT Join Date: Jan 2009
I'd buy it even if I had to modify the factory/aftermarket intake. Maybe include a intake with a diameter tube that matches the 1zz tb with a mount for the MAF sensor? Eagerly awaiting this to go up for sale.
^ Good ideas. Dyno session is Thursday, after that we'll figure out what we're doing next.
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
What is it with these intale manifolds all being dyno'd on thursdays???!!!
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Because it's the best day.
good luck Garm
05 Scion tC allmotor 350+ hp 9.34@144mph 05 Scion tC sfwd 880hp 9.96@147mph 05 Scion xB 280hp 12.97@104mph 07 Toyota Yaris 357hp 12.80@107mph |
jqueza@microimage
Drives: 2010 vios Join Date: Apr 2012
ill be waiting for thursday results cant wait!!!
#14 |
Form>Function
Drives: 07 Flint Sedan Join Date: Dec 2009
2 DAYS!!!
#15 |
![]() ![]() ![]() Drives: 2017 L 3-door Join Date: Mar 2011
I wonder if changing the intake manifold gasket to a non-metal material would help? More metal (compared to the plastic manifold) could translate to some heat soak?
#16 | |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
![]() I did the dyno runs without it and the manifold was blazing hot. That big one inch thick slab of aluminium "heatsink" laying across the intake ports transfers engine heat like crazy. I'm going to get longer bolts to put the insulating gasket on. Last edited by tooter; 09-04-2012 at 03:52 PM. |
#17 |
#1 Lemming
Drives: Light Blue '08 Yaris Join Date: Mar 2010
If I understand intake properly, you'd want more heat soak. Intake air temps you want to be lower, exhaust should be warmer. Heating the intake temps will rob some of the power (hence why cold-air intakes provide more power over short-ram and OEM)
Anyone feel free to correct me if I'm wrong. :EDIT: Completely misread, and didn't notice the "gasket" portion of what was said. Thought you meant the ENTIRE manifold... I'll go back to my corner now
#18 |
^ The manifold will get pretty hot from regular driving, especially stop and go, or "around town". Once you are moving pretty well, the longer runners will help protect against too much heat transfer.
The insulator/spacer might help a little. I'm not sure we'll be able to test one on the dyno though. |
| Mid-West Chapter Micro Image Car Club | lilredrocket | Southwest | 10 | 10-05-2009 01:06 PM |
| Turbo Manifold thread | Sabretooth | Forced Induction Forum | 78 | 05-22-2009 06:52 AM |
| Yaris Intake Manifold | richardholdener | Performance Modifications | 201 | 05-18-2009 11:58 AM |
| Intake Manifold Gasket? | Nexus1155 | DIY / Maintenance / Service | 6 | 11-18-2008 08:03 PM |
| Official Richard Holdener *MID-RANGE* Intake Manifold List | WolfWings | Performance Modifications | 59 | 11-13-2008 11:26 PM |
