Old 09-06-2012, 11:38 PM   #1
Intake manifold notes and specs from today. As always, you can count on full disclosure and 100% information when we have something to show you.
I'm pretty happy with the results.
Our manifold made some nice power in the 3000-5000 rpm range, where most people will use it well. With some tuning, the top end will yield some power as well, AFR went pig rich at 5500+
ambient temperature was 90 degrees F
87 octane (91 would have helped us)
tested on a stock Yaris
Engine and bay were hotter for the pulls with MI manifold
Dyno Dynamics (tough dyno with numbers, 10-15% lower than DynoJet)
***some changes and improvements to be made in production
rich on top -- will deliver more power with some tuning
no CEL's
sounds badass
Here is the dyno chart (sorry for the large image). Grey is MI manifold, the other line is stock plastic mani. Chart shows power and torque comparisons.
here's a YouTube vid:
http://www.youtube.com/watch?v=IIMXX8bw8lE
Old 09-06-2012, 11:41 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Do you have the AFR graph as well?
Old 09-06-2012, 11:45 PM   #3
We did not have a chance to test it with the 1ZZ throttle body today, but that probably would have helped a bit more. Just a guess. Future dyno session for sure.
Old 09-06-2012, 11:45 PM   #4
bluevitz, yes, I'll post that next.
Old 09-06-2012, 11:48 PM   #5
Old 09-06-2012, 11:51 PM   #6
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
Im liking this.
1zz tb and tune damn skippy
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 09-07-2012, 12:12 AM   #7
chaditotx
Drives: 2007 3dr hb 5sp
I wonder why the ecu decided to go so rich? I guess a tune will squeeze a bit more out.
chaditotx is offline   Reply With Quote
Old 09-07-2012, 12:40 AM   #8
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Congratulations, Garm! It looks like a really nice fat torque curve.
In what gear did you run it? My runs took about three times as long as your dyno video! Also what intake did you run on the throttle body. It was difficult to make it out in the video.
Old 09-07-2012, 12:34 AM   #9
4/20 NEVER FORGET
Drives: 2008 Yaris HB MT
I can't wait to buy one and install it with a 1zz tb. Any plans to try it out on a yaris with some mild mods? Id love to see how this does on a car with i/h/e and a 1zz tb.
4/20 NEVER FORGET is offline   Reply With Quote
Old 09-07-2012, 12:36 AM   #10
^ I sure want to or with a Zage kit at low boost.
I think I'll throw one on my car with a 70mm TB and see what it pulls too. Let's see what 25 psi does to it.
Old 09-07-2012, 03:04 AM   #11
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
gonna blow the welds right off the mainfold.
-Derrick-
Old 09-07-2012, 03:30 PM   #12
thefalls
Drives: Axio GT
This is going to be interesting!
Of course there will be gains over the plastic one.
Well lets find out with the boosted motors.
I better start saving!
thefalls is offline   Reply With Quote
Old 09-07-2012, 12:43 AM   #13
3rd gear pulls. Simota air filter (I think) on stock throttle body/MAF tube. (the rubber tube that feeds the stock airbox).
we tried pulls with and without air filter attached -- made no difference in power/torque at all.
Old 09-07-2012, 11:13 AM   #14
tooter
play every day
tooter's Avatar
3rd gear pulls.
Can you help me out here, Garm? Because now I'm really confused.
3rd gear would have been cheating anyway.
1 to 1 is the most accurate, and the pull is long enough to record with precision -- in tooter's case, great precision.
Old 09-07-2012, 08:10 AM   #15
malibuguy
Obsessed with 1.5L
Toyotas always seem to dump fuel on the top end. My tercel before the turbo would go to 10.3-10.5 range for the last 1200rpm...i called it Evo style...just blowing out black smoke.
Its also why i can get away with mild boost with no tuning...im still 11.6~ on the top end
-96 Tercel 4dr
Old 09-07-2012, 08:36 AM   #16
Yeah I observed that too on the 1NZ, perhaps it's a feature from Toyota engineers, prevent detonation in the worst possible conditions?
Old 09-07-2012, 03:49 PM   #17
chaditotx
Thats wild. As piston speed increases the likelyhood of autoignition decreases... maybe the ecm is throwing a lot of advance at that part of the curve too.
Old 09-07-2012, 07:22 PM   #18
malibuguy
Obsessed with 1.5L
My timing on the top end is around 24* iirc....stupid low timing if you ask me.
I used to run one oy old malibus at 15* initial and 44* total...ran awesome too
-96 Tercel 4dr
Mid-West Chapter Micro Image Car Club lilredrocket Southwest 10 10-05-2009 01:06 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
Yaris Intake Manifold richardholdener Performance Modifications 201 05-18-2009 11:58 AM
Intake Manifold Gasket? Nexus1155 DIY / Maintenance / Service 6 11-18-2008 08:03 PM
Official Richard Holdener *MID-RANGE* Intake Manifold List WolfWings Performance Modifications 59 11-13-2008 11:26 PM
