Old 08-30-2012, 11:42 AM   #1
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Wouldn't it be easier to take a honda fit HPD intake manifold and modify it to fit a yaris?
Both engines have about the same airflow requirements with the fit having more aggressive cams and a slightly higher rev limit.
Old 09-04-2012, 07:07 PM   #2
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I think the HPD manifold would experience some hood clearance issues as most of it is on top of the engine...
The engines are pretty similar in displacement and horsepower. Honda's being a 109HP 1.5L.
Old 09-05-2012, 02:01 AM   #3
ljming99
Drives: Yaris '06
Hmm, the specs i have here says the 1.3 is 100hp and the 1.5 is 120hp
VTEC JUST KICK IN YO!!!
ljming99 is offline   Reply With Quote
Old 09-05-2012, 11:55 AM   #4
tooter
play every day
tooter's Avatar
Yeah, I had looked at some old specs for an earlier year.
For 2012, they're:
117 hp @ 6,600 rpm; 106 ft lb of torque @ 4,800 rpm
But that extra power comes at the cost of some gas mileage at an EPA rated 27 city, 35 highway... as compared to the 2012 Yaris at 33 city 38 highway.
Old 09-06-2012, 05:57 PM   #5
tooter
play every day
tooter's Avatar
Since you guys are still waiting for Garm's results, here's the video of the tooter manifold dyno run to pacify you for a little bit...
http://www.youtube.com/watch?v=ifMAhFmwFU0
Old 09-13-2012, 01:45 PM   #6
etherdude
Drives: 2012 Yaris SE 5-speed
Tooter, have you blasted and/or coated your manifold yet?
etherdude is offline   Reply With Quote
Old 09-13-2012, 11:20 PM   #7
tooter
play every day
tooter's Avatar
I started blasting one manifold so far, but need more beads. By the time they make it into all of the corners of the cabinet, there aren't enough to be picked up from the bottom of the V bin!
I already ordered more and they will be here in just a few more days.
I'm using stainless steel blasting shot because the balls don't fracture like glass beads do. The tiny balls initially come covered with oxide and need to be "worn in" on a practice surface. I use a big brick of stainless steel, because that works best to shine up the balls for use. And as you continue to use the medium it gets harder and polishes better.
Stainless steel bead blasting is a relatively new technology, so there's very little information to be found. I scoured the web and could only find one person selling the beads in small lots. The only other sellers are the manufacturers themselves... three in China and two in India, and their minimum order is 2,000 pounds!
The beads give a nice low micro shot peened lustered surface without dimensionally altering the pieces. If there is a scratch on the surface, it remains there and just gets polished, so I'm going to do some surface prep with fine emery cloth before blasting.
I'm just beginning to learn this as I go and am having lots of fun improving on my technique.
Two more tooter adaptor flanges will come off the CNC machine tomorrow. After I pick them up, they'll go off to the welder, and then I'll blast the manifolds. I'll post a pic of the practice blasted surface tomorrow.
homemade intake manifold ttr125fan09 Performance Modifications 1 02-17-2012 01:09 AM
Custom Intake Manifold + Direct Port Nitrous blacksandiegovitz Performance Modifications 9 04-21-2010 07:05 PM
Turbo Manifold thread Sabretooth Forced Induction Forum 78 05-22-2009 06:52 AM
turbo manifold build... joey1320 Forced Induction Forum 4 06-30-2007 02:26 PM
